I think I BROKE it!!!
Old Feb 25, 2008 | 03:29 AM
E-250VAN's Avatar
E-250VAN
Red face I think I BROKE it!!!
I think I did a little water damage to my 96 E-150, 300 6
Was plowing the snow (Driveing thru the wet slush) the county puts
up on the curb, When the AMP gauge went to about + 2 volts! Lights
went almost COMPLETELY out! I shot back in the driveway, Let it idle
and it seems OK. What kind of damage might have occoured to cause that?
Kinda scary. Mabey it was just water getting somwhere it shouldn't be?
Did I damage it? Any thing I should look for? any IDEAS?? Thanks
Old Feb 25, 2008 | 08:01 AM
Ultraute's Avatar
Ultraute
I trust that you're telling us you were plowing "through" the snow/slush, and not doing snow removal.
Anyway, I suspect that you just have a bad connection somewhere that was jared loose for a moment. Check the connections at the battery and alternator, and make sure that the grounds are all good.
Old Feb 25, 2008 | 08:22 AM
jrh32's Avatar
jrh32
Did anyting else seems to not be working? Could have been water on the belt allowing the alternator to slip.
Old Feb 26, 2008 | 10:20 AM
rebocardo's Avatar
rebocardo
No damage, you just soaked the alternator with water. It does not hurt to check the connections, though you probably will not find anything wrong.
bballcrf
All Things Towing
Jan 22, 2017 09:40 AM
Rocketman55
Jul 21, 2013 11:06 PM
CountryD
6.7L Power Stroke Diesel
22
Apr 1, 2013 11:11 AM
dknouse
19
Sep 16, 2010 04:35 PM
e250guy
27
Sep 16, 2006 06:58 PM
