4 misfiring
Old Feb 24, 2008 | 06:59 PM
jimaug87's Avatar
jimaug87
4 misfiring
I'm a 20 year old, learn it and do it yourself, college student. I got a check engine light and the code came back as a bad EGR and a cylinder 4 misfire. I'm grabbing a new EGR valve from the boneyard this week, but the misfiring is worrying me.
1996 F150 4x4 5.0 5spd
The wires looks good, and so do the plugs. I seafomed it about 2 months ago. Which cylinder is #4, and what can i do to try and fix it?
I'll bring it to a mechanic if I HAVE HAVE HAVE to, but I'd love to be able to not ever have to do that again.
Thanks for any advice you guys can lay on me.
Old Feb 28, 2008 | 09:30 AM
jimaug87's Avatar
jimaug87
(Bump) I'm sure someone around here has some input. I'm driving my truck home from college (60-70 miles highway), and I'd like to be able to to try and remedy the problem before that.
Old Feb 28, 2008 | 10:15 AM
rollingthunder-1's Avatar
rollingthunder-1
when was the last good tune up? cap, rotor, plug wires ( can look good, but can be bad) and plugs. again plug can look good but be bad. for couple of bucks change the plug out, may be fouled
Old Feb 28, 2008 | 10:24 AM
quicklook2's Avatar
quicklook2
on six the 4th from the front.
on v8 last on passenger side by heater.
a manual is your friend.
Old Feb 28, 2008 | 10:37 AM
Conanski's Avatar
Conanski
Don't rely on the look of the wires, that doesn't tell you anything. Measure them with a DMM, they should measure about 5k ohms per foot when disconnected from the plug and distributor cap.
Old Feb 28, 2008 | 11:44 AM
jimaug87's Avatar
jimaug87
I don't have a meter at school, but I'll test that with my grandfather's when I do get home.
I've been slowly tuing it up as i go, but my lack of funds does make plugs, wires, and cap expesive. I needed to hear you guys say it could be an issue before I spent the money. My economy sucks too, so hoepfully that will give me a couple % increase as well.
Old Feb 28, 2008 | 11:59 AM
Conanski's Avatar
Conanski
You can also test the relative health of the wires if you start the vehicle in a completely dark location like inside a garage at night with the lights off(may have to disconnect daytime running lights). If you can see a lightshow under the hood you have bad wires.
brianwlr
2004 - 2008 F150
Nov 8, 2014 06:24 AM
ParisDakar
1997 - 2003 F150
Aug 23, 2012 01:40 PM
coffia82
1997 - 2003 F150
Dec 16, 2010 03:15 PM
Stationwagonguy
3.8 & 4.2L V6
Jul 26, 2008 11:06 AM
BlueOvalfan85
Jun 15, 2008 12:08 AM
