Fluid change
Old Feb 24, 2008 | 05:16 PM
OldMetal's Avatar
OldMetal
Fluid change
I feel dumb asking this as I've a mechanic most of my life but on my 77 F150 4X4 there are no diff drain plulgs, whats the best way to change the fluid in them? Does one of the bolts go all the way through or do I just use a suction tube?
Old Feb 24, 2008 | 07:09 PM
whd507's Avatar
whd507
on the front you just pop the cover off, and replace the gasket. I assume you have a 9" in back, you could pop axles out and drop the 3rd member, (good time to check and adjust gear lash) or just suck it out. I don't think any lower studs come out easily. if its not the 9" same as the front.
