few misc. questions
Old Feb 24, 2008 | 04:07 PM
69ford99's Avatar
69ford99
few misc. questions
I have a '04 FX4 Screw with factory 17's and I know the biggest tire you can put on without a lift is 33's but will those fit on my stock rim? My front two power window buttons don't glow how do I fix that? My dome light on the overhead console is out how do I get to the bulb?
Old Feb 24, 2008 | 08:34 PM
KevinAH's Avatar
KevinAH
I think you can get the bulb at the auto parts store in the bulb section. Just look it up in the catalog. There is usually an entire row of part numbers for the correct bulbs from headlights, tailights, glove compartment, etc. I am also interested in the non glowing window buttons. I have the same year and truck as you and have the non glowing buttons, maybe it was an option.
Old Feb 24, 2008 | 09:26 PM
69ford99's Avatar
69ford99
the window buttons are suppose to glow the two front ones on the drivers side are very dim and I don't know how to make them bright again like the others.
Old Feb 24, 2008 | 09:34 PM
Twinsdad98's Avatar
Twinsdad98
Search the forum for dome lights and map lights. THere was just a thread recently about changing the bulbs out for Putcos LED. They had directions on how to change them out as well. I also have a 04 Lariat, but I don't think the window switches light up.
Old Feb 24, 2008 | 10:10 PM
KevinAH's Avatar
KevinAH
All my window switches used to light up. Now....the 2 drivers side and passenger button(drivers side) do not light up. Not just dim, gone. I also have an 03 Ranger that this has happened to. Probably a bulb inside there that has run out of life.
Old Feb 24, 2008 | 10:12 PM
04 FX4 Lineman's Avatar
04 FX4 Lineman
All 04 window switches lite up I just had mine changed under warranty all 4 switches are in one module and they change them all when u do the module not sure how they come off but the dealer did them in about 30min. or less.
