Question about AIH Delete
Old Feb 24, 2008 | 12:30 PM
jeff7825's Avatar
jeff7825
I put in my AIH Delete plug from dieselsite a little bit ago, and I have a question. I removed the ground wire because I didn't want to have a wire just hanging there, and I didn't realize it until after I took the wire off of the block, but I removed the whole stud out of the block. My question is, will there be any effects of this? I wouldn't see why there would be. Install was really easy though, took maybe 10 min. at the most.
Old Feb 24, 2008 | 12:34 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
If you didn't reattach the blue wire you will not be able to complete a diagnostic test on the truck, but other than that there will not be any other problem.
Old Feb 24, 2008 | 12:57 PM
jeff7825's Avatar
jeff7825
Yes I did reattach the blue wire. Thanks I didn't think that there would be a problem but I just wanted some reasurance that I was right.
