let off for od
Old Feb 24, 2008 | 08:08 AM
haul_um_all's Avatar
haul_um_all
Smile let off for od
Hi i have a 90 f150 5.0 engine my problem is i have to let off the gas to get it to shift into over drive. anyone else have this problem. i have had the fluid recently changed the truck just has 82000 miles. it seem to pull normal and shifts fine from first to third. thanks to all.
Last edited by Ultramagdan; Feb 24, 2008 at 08:56 AM. Reason: Moved to proper forum
Old Feb 24, 2008 | 09:02 AM
Linemo's Avatar
Linemo
what transmission do you have that will help determining the trouble?
Old Feb 24, 2008 | 11:38 AM
haul_um_all
Smile
I don't know what trans it is it's a 1990 f150 xlt lariat auto 3 speed with overdrive. where would i look to find out which one i have? thanks again for all reply's.
Old Feb 24, 2008 | 11:44 AM
fmr9's Avatar
fmr9
If you use the search feature of this forum, you will find an amazing amout of information. Spend a few hours reading and you will know a whole lot more about your truck than you do now.
Good luck Frank
