Low Boost 5psi max
Old Feb 23, 2008 | 09:55 PM
LBCMS's Avatar
LBCMS
Low Boost 5psi max
Whats the deal got everything going finally and im only getting 5psi max boost. cdr on intake is blocked no other gapeing holes that i know of. had to back off the IP flow screw so now its only one flat from its orignal setting rather then bottom out like before. what am i missing? i have the Hypermax kit on the 86 f250 6.9L
Old Feb 23, 2008 | 10:33 PM
1994diesel's Avatar
1994diesel
is it waste gated? ive been told that shortening the rod will bring up your boost, im gona try that.
Old Feb 24, 2008 | 12:31 AM
George D.'s Avatar
George D.
I don't think the hypermax is waste gated the only way to get more boost is free up the intake and exaust and turn up the fule. also the load on the truck will afect it. I'm not too familliar with the hypermax turbos may not build full boost without a good load. Also chack for boost leaks and exaust leaks befor the turbo.
I tryed shortening the rod on my waste gate but I'm still maxing a 7psi full throtle empty and it gets there quick so Next I'm gona turn the fule up a bit and see what hapens.
Old Feb 24, 2008 | 09:02 AM
Dave Sponaugle's Avatar
Dave Sponaugle
George do you still have the stock down pipe on your turbo?
That smashed pipe will make the turbo spool slow and limit the max boost.
Old Feb 24, 2008 | 09:59 AM
84-6.9's Avatar
84-6.9
When I put my kit on with the pump open 1 1/2 flats 5pis was it, open it to 21/2 and you should see 8 psi and the boost guage needle should be a little more lively.
Old Feb 24, 2008 | 10:06 AM
Dave Sponaugle
Non wastegated turbos have four things that limit boost.
The design of the turbo
Exhaust restriction
Intake restriction
The amount of fuel burnt making heat
Old Feb 24, 2008 | 11:10 AM
George D.'s Avatar
George D.
Yeah I'll be getting read of the squish pipe when I get my tax return.
Old Feb 25, 2008 | 03:55 AM
LBCMS's Avatar
LBCMS
yeah its a non waste gated turbo. thay claim boost off idle and up to 12 psi boost hmm i think i got haggerd. i should throw my cummins D50 turbo on there lol it weighs like 100 pounds and about 10 time bigger lol
Old Feb 25, 2008 | 03:57 AM
LBCMS's Avatar
LBCMS
oh and the fuel flow i bottom out about 2 and 3/4 flats but i backed it off a bit about 2 flats now i had a seriuos proble previously when it was bottomed out
