I still have a little bit of fuel leaking because I had 2 more return lines split. Fortunatley it is just a minor leak on 2 injectors. Had to charge both batteries overnight and finish bleeding the air out of the fuel system this morning and a couple shots of starting fluid later it was sounding good.
