siting pritty
Feb 23, 2008 | 05:17 PM
siting pritty
guys I just got 1989 f250 4x4 and need to get her siting up right .on so 35's
Feb 23, 2008 | 06:45 PM
We need a little more info or do some reading and researching man!!!
How hard and how much do you go wheeling.
Is this a daily driver.
How much do you want to spend for improvements.
What motor "size".
What tools do you have, and access to parts and garage.
ect ect
NIck
Feb 23, 2008 | 06:50 PM
sorry yes its a dd its got inline 6 I would like 2 put 33''or35s on it it has 4.10gears 2 .I would like to get back in woods unassumed roads and and look more nicer
Feb 23, 2008 | 07:24 PM
Ok I didnt mean to jump down your throat or anything.
I would try someplace like Bronco graverard or skyjacker. You will want a full kit with front and rear springs, no blocks.
If im right you should be able to fit 33s almost stock with minimal rubbing. 35 should fit decent with a 4inch lift kit.
Your gears should be fine since they already are 4:10s.
Feb 23, 2008 | 09:18 PM
yep that should about cover it, you might want to look into some lockers or a limited slip also.
Feb 24, 2008 | 09:55 AM
straight axle the front!!!
Feb 24, 2008 | 03:37 PM
thank 4 the help yes it has a solid frort axel and its got 4.10s with Ls
Feb 24, 2008 | 04:51 PM
did you put the straight axle in the front or did it come that way from the factory???
Feb 24, 2008 | 05:22 PM
it was like that when i got it.It looks stock
Feb 24, 2008 | 05:33 PM
does it look like this???
Feb 24, 2008 | 06:36 PM
89 f250 didn't come with come with straight axle.
Feb 24, 2008 | 06:45 PM
thats why im wondering if someone swapped it in?? and if it is he shouldnt need any lift to stick 35s under his truck
Feb 24, 2008 | 07:51 PM
heck no if its got a straight already, he can go with 36 with no lift, just need to trim the bumper a little. so.... you def have a straight in there? cause if you do.. lets see pics..
Feb 25, 2008 | 09:12 PM
The truck is still parker a my buddys house.But when i get her home and fix the tranny I will put up some pic's
Feb 25, 2008 | 09:32 PM
does the front end look like the pic i posted thou???? theres a big difference in lifts if it does thats why im asking.
