Keyless entry schematic
Old Feb 23, 2008 | 04:11 PM
rustydailey's Avatar
rustydailey
I'm looking for a schematic for the keyless entry system for a 99 to 04 SD so that I can add on to my truck. I'm trying to find one in a wrecking yard and need to know where to look for the required parts and the associated wiring.
Rusty
Old Feb 23, 2008 | 04:47 PM
ReAX's Avatar
ReAX
12volts yellow & lt. green/purple + ignition harness
Starter green + ignition harness
Second Starter N/A
Ignition red/lt. green or white/yellow + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory gray/yellow & red/black + ignition harness
Second Accessory blue/lt. green + ignition harness
Keysense
Power Lock see notes
Notes: Without keyless entry use pink/yellow for lock and pink/lt. green for unlock. They are 5 wire reverse polarity mastered from the driver switch and found in either kick panel. With keyless entry use white/red for lock and black/white for unlock. They are negative trigger and found at the VSM.
On the vehicles with keyless entry the GEM shuts down after the doors have been locked for a certain time period, to wake up the system refer to DirectFax document 1094.
Power Unlock see power lock notes
Lock Motor pink/black 5wi VSM
Notes: The VSM (Vehicle Security Module) is to the right of the accelerator pedal above the transmission hump below the radio. Not accessible from radio opening.
Unlock Motor red/orange 5wi VSM
Parking Lights+ brown + headlight switch
Parking Lights- N/A
Hazards same as turn signals
Turn Signal(L) lt grn/wht (F), lt grn/org (R) + steering column
Turn Signal(R) wht/lt blu (F), org/lt blu (R) + steering column
Reverse Light black/pink + fuse box
Door Trigger black/lt. blue + either kick panel
Dome Supervision use door trigger
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer NOT red/lt. green ac any ignition coil
Notes: On diesel vehicles the tach wire is green/white in a 5 wire harness held up with white tape behind the parking brake release.
Wait to start see DirectFax document 1091
Brake Wire lt. green + brake pedal switch
Parking Brake lt. green/red - parking brake switch
Horn Trigger blue - steering column or VSM
Memory Seat 1 brown/lt. green - memory mod under dr seat
Memory Seat 2 black/orange - memory mod under dr seat
Memory Seat 3 N/A -
Immobilizer Bypass Module: Required: No Type: N/A Part #: N/A
Notes: N/A
Old Feb 23, 2008 | 04:56 PM
AustinS's Avatar
AustinS
If you already have power locks, an easier task would be to install a remote start unit. Most of them have keyless entry, and if you get one with a superheterodyne antenna, the range is many times that of a stock system.
Plus, you get the convenience of remote starting your truck when it's colds outside. Most of them also have a built in turbo cool down timer feature.
The thing I enjoy the most is the power window roll up module. I can hit a bitton on my key fob and it rolls up the windows for me. It's great when it starts raining and I just need to push a button instead of running down stairs or to the other end of a parking lot.
The only thing I liked better about the stock system on my truck is that the key fobs are sturdier. That being said, I still prefer the remote start over the factory system, and I will be installing one on every vehicle I own for the rest of my life.
Austin
Old Feb 23, 2008 | 07:58 PM
dc2842002's Avatar
dc2842002
If you just want keyless entry you can get a ford unit from http://www.troyfordaccessories.com/ You only have to wire up two relays and connect into 6 or 7 wires on the truck.
Old Feb 23, 2008 | 08:13 PM
rustydailey
What I really want is the keypad on the door. That way I don't have to worry about locking my keys inside. I figured that it would be easier to get one from a junk yard.
jeezjamie
1997 - 2003 F150
Jun 26, 2012 07:00 AM
rustydailey
Electrical Systems/Wiring
Mar 1, 2008 09:12 PM
RMA
Feb 12, 2008 01:38 PM
RMA
New Member Introductions
Feb 11, 2008 04:12 PM
