Another Brake question
Old Feb 23, 2008 | 04:00 PM
55FORD352's Avatar
55FORD352
1977 F150 4x4, no cruise control, - The question is, should the brake pedal be at the same level as the gas pedal? I have replaced the MC and Booster and all brake parts. Brakes work, but the pedal seems to be far to low to allow for enough travel. Any thoughts on this???
Old Feb 23, 2008 | 04:11 PM
tractoman's Avatar
tractoman
On my SC the brake pedal is much higher than the gas pedal. It's a 460 with a C6 and CC though.
Old Feb 23, 2008 | 04:14 PM
55FORD352's Avatar
55FORD352
Yes, I have a 73 F100 and the brake pedal is about 2 inches higher than the gas pedal, but it is not power brakes, so I was thinking that power brakes may have a lower brake pedal. Sure wish I could find a 77 f150 to look at.
Old Feb 23, 2008 | 04:15 PM
OldMetal's Avatar
OldMetal
There should be a rubber bumber or stop that the pedal should come up to.
Check to see if it's coming up to that.
Old Feb 23, 2008 | 04:22 PM
55FORD352's Avatar
55FORD352
yes, the "stop" is the brake light switch, which is part of the pedal. It comes up to just fine.
Old Feb 23, 2008 | 04:27 PM
OldMetal's Avatar
OldMetal
I just went out and looked at my 77 and the pedal is about two inches higher than the gas pedal, the switch should not be the stop and is adjusted to where the pedal comes up to the stop.
Old Feb 23, 2008 | 04:29 PM
55FORD352's Avatar
55FORD352
Well, that's great. I knew the pedal should be higher, now I have to figure out why it is not. Any ideas???
Old Feb 23, 2008 | 04:33 PM
OldMetal's Avatar
OldMetal
Check and make sure the switch is not acting as the stop. If the pedal is coming up all the way to the stop all should be fine, it's possible someone replace the switch and did'nt adjust it right.
Old Feb 23, 2008 | 04:36 PM
55FORD352's Avatar
55FORD352
Thank you for your help, I am going to remove the brake switch and see how far the pedal comes up., If it doesn't come up any higher, then I guess I will have to search further to find the problem.
Old Feb 23, 2008 | 04:41 PM
OldMetal's Avatar
OldMetal
You should be able to just look and see.
No problems on the help though.
Old Feb 23, 2008 | 05:12 PM
55FORD352's Avatar
55FORD352
With the brake switch removed the pedal does not come up any higher. The only stop is the flang that the brake switch hits on. What am I missing???
Old Feb 23, 2008 | 05:38 PM
55FORD352's Avatar
55FORD352
If the MC was removed from the power booster, where should the brake pedal sit?? Is the height of the pedal determined by the MC pressure back against the power booster???
