rear window
Old Feb 23, 2008 | 09:37 AM
grizzqc's Avatar
grizzqc
rear window
will the rear window from a 92 f150 4x4 fit in the rear window of a 1988 f150 custom both king cabs?The 92 has the sliding windows mine is solid.
Old Feb 23, 2008 | 09:44 AM
19FORD93's Avatar
19FORD93
I would imagine yes. According to LMC's catalog their rear slider is 80-96. i would like to believe you can swap them out.
Old Feb 23, 2008 | 10:07 AM
JohnT's Avatar
JohnT
Smile
Actually, the rear windows from 1973-1996 are interchangeable. I doesn't matter whether it's a sliding window or solid glass, they are all the same size.
Old Feb 23, 2008 | 11:08 AM
flareside_thunder's Avatar
flareside_thunder
Yes it will fit...and if I remember right even a few from the 70's will fit as well.
JR
flareside_thunder
whoops didn't see that.....
JR
Old Feb 23, 2008 | 03:18 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The gasket for the slider will have a wider glass groove.
.......If it's factory......
Old Feb 23, 2008 | 04:07 PM
grizzqc's Avatar
grizzqc
but it fits if i buy a new gasket
Old Feb 23, 2008 | 04:13 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Yes, I believe it should.
Can't you get the gasket w/ the window?
I say this because I HAD a factory slider, blew it out w/ a huge stack of plywood. Bought a 'replacement' rear sliding window and it only had a thin flange(meant to fit in place of a single pane) and would not fit tightly in my gasket w/ the wider groove.
rangergirl94
Feb 22, 2012 06:46 PM
Anafiel
WTB - Parts & other
Feb 22, 2011 09:41 AM
rack04
2004 - 2008 F150
Dec 21, 2004 12:02 PM
Supercab
1978 - 1996 Big Bronco
Apr 13, 2003 12:29 PM
