flushin the coolant
Old Feb 23, 2008 | 08:12 AM
cracked block's Avatar
cracked block
flushin the coolant
Is there anything special about flushing a 2000 v6 motor? Someone told me the system was under pressure. Never heard of such a thing. Thanks.
Old Feb 23, 2008 | 08:42 AM
jimdandy's Avatar
jimdandy
The system is only under pressure when the cap is on and the engine is hot. Engine cold, or cap off, no pressure. To flush the engine, remove the thermostat and run water thru the engine, top to bottom with a water hose.
You can buy flushes at your local auto parts, but according to radiator shops in my area, they are a waste of money. They will not touch the hard lime and other deposits that build up in the system. jd
Old Feb 23, 2008 | 09:04 AM
aquanaut20's Avatar
aquanaut20
Remember the coolant is sweet and toxic so be carefull where you flush and clean up after.
Terrible way to die for the kid or animal that drinks it.
