Rear spring question?
Old Feb 22, 2008 | 09:08 PM
schmuly's Avatar
schmuly
Question Rear spring question?
I have an '02 f250 PSD and I believe the rear springs are weak for my camper. I would like to know if rear springs from any 99 and up F350 would fit. With the camper the A code F250 rear springs are almost bottomed out. Would B or C code F350 rear springs fit and would they give the same ride height. I do not want to lift my truck any higher than it is. I have air bags on the rear and they worked great, but while I was driving home with the camper (just bought it) For some strange reason the bags deflated and I think I screwed one up. I tried filling them up at a gas station on the I-5 and .75 cents later they went up 2 inches then deflated. So I drove from Mt. Shasta up the I-5 to Portland then home. That 7.3 was great on the I-5 better than I could have imagined going over the passes.
I weighed the rear axel when I got home and it weighed 3030kg or 6666lbs. The A code springs are rated for 6,084lbs and the B code are 6,830lbs. Have I got my info correct?
So would the F350 springs fit and help solve my problem?
Colin
2002 F250 CC lariet longbox
PSD auto 4x4
"now with camper"
Old Feb 22, 2008 | 09:24 PM
JoeTrotter's Avatar
JoeTrotter
They'd bolt up, don't know about the ride height. You could also put a helper or overload spring on if it needs more help.
Old Feb 22, 2008 | 09:54 PM
schmuly's Avatar
schmuly
Talking
I was hoping they would, I changed the front ones when I bought the truck becaused the travel on the front was 1/2 in on one side and 3/4 in on the other side. Measured from the rubber bumperette to the axel. If the front were fatiged the rear must be with a load on also.
I will start looking for some F350 rear springs
Colin
Old Feb 22, 2008 | 10:46 PM
bdrummonds's Avatar
bdrummonds
Colin
$145 per side from direct ford parts. look for the thread in the past couple of days that is titled "ed at Y2K ford parts where are you" The dually springs(C codes) will also fit, but it will ride rough.
Old Feb 23, 2008 | 09:23 AM
F350-6's Avatar
F350-6
I'd fix the air bags, and get a set of overload springs. Even if you swap to the 350 springs, make sure you get the overloads.
Old Feb 23, 2008 | 11:37 AM
FordGuy_till I die's Avatar
FordGuy_till I die
99.9% of the time air bag deflation is due to an air line that has been damaged.
Old Feb 23, 2008 | 12:32 PM
schmuly's Avatar
schmuly
Thumbs up
Thanks to all who responded.
These were brand new air bags , that I bought unopened off Craigslist so no retail reciept. They were only on the truck for 3 days
, then we left to go to Califorina to pick up the camper. Half way back they sometime they deflated, and I probably drove 200 miles or more like that. I will buy new bags and try it again ,but I still want to put the F350 springs on for the extra weight of the camper
Old Feb 23, 2008 | 12:43 PM
rbaker6336's Avatar
rbaker6336
I would chech the bags befor replacing the normally if the don't get a hole rbbed in them it is a line or fitting
Old Feb 23, 2008 | 01:11 PM
yellow401's Avatar
yellow401
I noticed I've got a broken leaf in the rear, right above the lift block. Are the 350 springs different from the single and dually trucks? I'd like to run the 350 springs.
Old Feb 24, 2008 | 09:24 PM
schmuly's Avatar
schmuly
Talking
I found a set of b-code springs thanks everyone
Colin
