No kick down
Old Feb 22, 2008 | 07:11 PM
RP27G8G's Avatar
RP27G8G
No kick down
I have a 91 F 250 and I have no kick down when I press the gas pedal down. I've had the trans out a couple of times but I know I got everything hooked back up. Is there a sensor or something that may have gone bad? Thanks in advance.
Old Feb 22, 2008 | 09:51 PM
PLC7.3's Avatar
PLC7.3
The E4OD uses the FIPL(TPS) to tell trans to down shift......... have you ever reset the FIPL to specs.
Old Feb 22, 2008 | 10:03 PM
RP27G8G's Avatar
RP27G8G
Thanks!! I don't know what the FIPL is. Any help will be greatly appreciated.
Old Feb 22, 2008 | 11:36 PM
George D.'s Avatar
George D.
FIPL fuel injection lever position sensor. basicly the diesel version of a TPS. I need to adjust mine as well pretty sure its the problem. PLC7.3 has all the info on adjusting it.
Old Feb 24, 2008 | 11:56 PM
ford trans tech's Avatar
ford trans tech
which transmission does the truck have
Old Feb 25, 2008 | 12:24 AM
George D.'s Avatar
George D.
Oops meant to say fule injection pump lever sensor.
Old May 12, 2008 | 09:56 PM
RP27G8G's Avatar
RP27G8G
I found the original post. Looks like it is the TPS. Guess I'll go buy a new one and see how it goes. Thanks!!
