Sponsored by: Auxito
Air Bag Crash Sensor #2
Old Feb 22, 2008 | 01:15 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
My brother has a '97 F-150, i'm posting this question for him. Upon startup, he gets an alarm noise coming from the right corner of the dash, about 5 beeps consecutively, and then a pause, repeated 5 times for about 25 seconds. I hooked up my AutoEnginuity and found a code, it was an air-bag crash sensor. I'm assuming this is some sort of sensor on the outside of the truck that senses impact or forces that would normally deploy the air bags. We are guessing the sensor is bad, or needs attention. If anyone knows where this is, it would be very helpful in getting this safety hazard fixed!
Thanks FTE
Old Feb 22, 2008 | 01:45 PM
KingRanchMan02's Avatar
KingRanchMan02
If I'm not mistaken, it is just a burned out lamp in the air bag switch on the dash panel in front of the passenger. Have him verify that the light illuminates when the igntion is turned on. If it does not come on, there is a Radio Shack lamp that can be installed to make it work again which is much more reasonable than replacing the part through Ford. Someone else will chime in with the part number for you. Good luck!
Old Feb 22, 2008 | 01:53 PM
antony25's Avatar
antony25
The beeping is from a burned out air bag lamp in the cluster not the PAD lamp.Turn the key on and see if the air bag light illuminates for a couple seconds.
Old Feb 22, 2008 | 02:04 PM
PowerstrokeJunkie
Thanks for the input, we'll check and get back. I do know that when you use the key to turn the airbag off, it does illuminate. Does that affect anything?
Old Feb 22, 2008 | 02:11 PM
KingRanchMan02
It disproves my suggestion and sends you in anthony's direction. Good luck!
