1993 Explorer - cold tranny problem
Old Feb 22, 2008 | 12:54 PM
Rider Pride's Avatar
Rider Pride
My '93 explorer (188000 km's) experiences tranny (4x4 auto) problems when cold.
Summer - no problem.
Winter - reverse works fine, but forward does not engage until engine has warmed up for 20 minutes or more (I put the truck into gear, but it does not move).
I had the tranny serviced last fall (new fluid, filter, gasket, inspection) but tech did not notice any mechanical problems. He suggested re-build if the service did not solve problem.
The gear selector needle does not line up with D, so I usually have to fiddle with the selector to get it into gear.
Any suggestions on problem/solution?
Old Feb 22, 2008 | 12:58 PM
aquanaut20's Avatar
aquanaut20
Make sure your fluid is at the correct level, this behaviour is indicative of low fluid (ATF)
Old Feb 22, 2008 | 04:01 PM
jg09's Avatar
jg09
I kind of have that problem. When it's cold, it sometimes feels like the e-brake is sticking, although I know it isnt. For a while, shifting out of Overdrive fixed the problem, but now it's not as much. My fluid is full and in great shape.
Old Feb 27, 2008 | 12:51 PM
Rider Pride
Fluid level is fine (hot - in hatchmark on dipstick).
Should also mention that 1-2 upshift is extremely delayed (usually redlined) during first acceleration. Seems to be normal after that.
Old Feb 27, 2008 | 04:39 PM
aquanaut20's Avatar
aquanaut20
sounds like it is not getting the proper fluid intake on first start, have you checked the filter?
Is it the correct one, is it fitted square(sucks air from above fluid if installed crooked or not fit correctly), clean?
Running "REDLINED" means it is slipping and so will burn and die.... P
Old Feb 28, 2008 | 10:05 AM
Bear River's Avatar
Bear River
Former ******
If the fluid level is fine, it should be to the bottom hole in the dipstick when cold. If it drops below that there can be engagement issues.
If the fluid level is fine, it means either a problem with the valve body, or the bands are slipping and need to be replaced. Some people will simply adjust the bands, but by the time they have worn enough to start noticeably slipping, they are very thin (they are thin to begin with). If you tighten them, they will mask their failure. There are 3 stages of a bands life. The first stage is when they are new. The surfaces are strongly bonded friction materials that don't allow much slippage. The second stage is that when they start slipping, the surface begins to scorch, and once the surface begins to break down it enters the third phase. The third stage is the shed phase, where the material has been compromised and begins to self destruct. The material that bonds the friction particles together no longer has the strength to hold itself together.
