Oil drain plug leak
Old Feb 22, 2008 | 12:29 PM
Cpljdrose's Avatar
Cpljdrose
Question Oil drain plug leak
I own a 2000 Ford Excursion with the diesel engine. The oil drain plug has an annoying slow leak/drip. I have tried a new drain plug with no luck. The dealer says that the drain plug does not have a washer that goes with it. Anyone have any simple safe fixes. Thanks... So far I have changed out all the door actuators, front springs, shocks, calipers, brake rotors and the water pump. Just can't fix this leak !!
Old Feb 22, 2008 | 06:06 PM
dimambro2's Avatar
dimambro2
try going to an auto parts store and getting a copper crush washer that fits over the bolt. It worked on other Trucks for me my X has the same problem going to do it the next oil change. cant be more then a couple of bucks.
hope this helps
chris
Old Feb 22, 2008 | 06:35 PM
CanadianSmokie's Avatar
CanadianSmokie
Get and install a Fumoto valve....
http://www.fumotousa.com/
Once installed, you'll never have to worry about stripped threads, crush washers, etc, ever again.
