Need help with tires
Ford switched to the silly little ones for reasons that have
nothing to do with non-impaired people using quality tires.
BFG AT KO's are one of the best tires on the market, except
they may not last as long as you would want. 30-40 K is good.
BFG MT are wonderful tires off road, and work reasonably well
on pavement, they are noisier and don't last as long as the already
somewhat short-lived AT's.
If you drive almost exclusively off-road, get the MT. Otherwise get the
AT's, as long as the $$ per number of miles equation fits your budget.
Tire shops are all over the place about what they can/will/won't/don't install.
My local Ford dealership (used to) put 315/75/16 BFG's on the stock rims with a 4" lift all the time, still does on the SD P/U's.
Allen tires won't put bigger than 295's on the stock rims.
America's will also put the 315's on (my favorite cuz I drive a LOT of off road)
_____________________
Quietman
www.roenation.com
2005 EXCURSION LIMITED-options (everything) equipped Eddie Bauer edition 4X4 PSD
4" FabTech lift/level, Bilstein $$ mono-gas shocks, Rancho Steering Stabilizer
Silverstar 9005 fog and H13ST headlights + wiring mod to run high beam and fogs together,
BFG 315/75/16 AT KO's on Factory Mags, 22" front and 18" rear rain-x wipers,
LANDYOT Generation II Radius Rods, Ford factory hood insulator, Movaje Pin-Striping
