rear main seal type
Old Feb 21, 2008 | 11:31 AM
cscott952's Avatar
cscott952
rear main seal type
I have a '85 F150 302, and wonder what type of rear main seal it has. I am pretty sure from looking at it that its a 2 piece. You can't see any of the seal with the flywheel off. My Chiltons books says its a 2 piece, but parts sources including Ford and Napa show a 1 piece on it. Is it suppose to be the 2 piece? Is the 2 piece the rope style?
Thanks,
Casey
Old Feb 21, 2008 | 06:49 PM
Franklin2's Avatar
Franklin2
If you can't see the seal, it's a two piece. If someone's been there before, it may have a rubber seal. If it has the rope, you can buy the rubber to put in it. Just make sure you drive the little stick pin out of the main bearing cap if you go with a rubber seal.
Old Feb 21, 2008 | 10:59 PM
cscott952's Avatar
cscott952
Napa shows either the rope or the rubber. I should get the rubber one then?
shore
1978 - 1996 Big Bronco
Nov 14, 2013 12:01 AM
Roger51
Dec 6, 2012 11:05 AM
Thumper19
Jan 10, 2012 09:02 PM
Mr Man
Apr 18, 2002 07:07 PM
gi_tanker
May 26, 2000 01:03 PM
