Banks PowerPack system
Old Feb 21, 2008 | 12:16 AM
jllang2's Avatar
jllang2
I found a package from banks power that claims to give a 45hp gain and a 47 lb-ft gain to the 5.4. I was wandering if anyone had experience with the product and if it was all the site made it out to be?
Old Feb 21, 2008 | 02:04 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
go to spike.com and look up the show Trucks. last year they showcased that package on the F-150. if you watch the show, it was all b.s. they dyno'd the truck while the engine was hot (heat affects peak HP, hotter=less hp). I think they claimed it got 197 or 201 rwhp (sorry, too lazy to google it myself again)
I can believe the +45 hp claim if you go all out (exhaust, tuner, headers, intake)...but honestly, you'll most likely only get about 260 ish to the rear wheels. most F-150's can dyno out at 245-250 rwhp stock
all in all, I'd spend the money elsewhere.
$400 for Edge or Xcal Tuner
$100-500 for Dual Exhaust Catback
$250 for CAI
$500 for 4.30 - 4.88 gears
you can do all the above and have a real FUN truck...and still come in cheaper than the Banks power package. wasn't it about $2k
Old Jul 15, 2008 | 05:15 PM
jbarker_bankspower's Avatar
jbarker_bankspower
$250 for CAI
Actually if your going to do a true measure of the engines performance you HAVE to run the test with a hot engine. The only reading you will get with a cold engine is a sky high number that you won't be able to reproduce. For a consistant dyno reading (to get a true reading of the changes you made) the engine, coolant, oil, and driveline need to be up to full opperating temps. You won't be driving on the highway with an ice cold engine. Also the Banks Power Pack system with Ram Air intake, Torque tube headers, Monster cat back dual exhaust and Ottomind programmer is about one hundred dollars more then your list and installation can be done at home with basic hnd tools. The gain at the ground is 45hp and 47lb-ft.
Sam,D
Jun 17, 2016 02:16 AM
94fordiditurbo
Nov 23, 2015 10:13 AM
andy9743
Jul 2, 2015 10:15 PM
JHoffman93
Apr 6, 2013 03:48 AM
Shade
Jun 15, 2009 05:51 PM
