powersteering leak
Old Feb 20, 2008 | 10:27 PM
V10man's Avatar
V10man
powersteering leak
My son's 92 F150 4x4 has developed a leak at the output shaft. Bad leak. I see at NAPA you can buy the seal for like $6. The truck also has a wander at freeway speeds. Question is, should I try and replace the seal or just buy a rebuilt box and be done with it? It has around 100k miles.
Old Feb 21, 2008 | 07:03 AM
Lazy K's Avatar
Lazy K
Why not try the seal kit? The seals are quite easy to fit and the most you would lose is $6 plus 30-40min of time. If the play is in the steering box you should be able to adjust it out with the adjuster on top of the steering box.
