solar question
Old Feb 20, 2008 | 09:19 PM
alberta46's Avatar
alberta46
solar question
I have just bought a new tt and was wondering if I could get some advice. It has the fridge furnace and hot water tank and I was wondering how big of a solar panel I would need to keep the battery charged for say ten days of camping? I have a 5.5 watt now but I think all it does is maintain or charge slightly any help appreciated.
Old Feb 20, 2008 | 09:42 PM
kermmydog's Avatar
kermmydog
You're Refer & hot water heater work on 12V? Your refer & hot water heater should work on propane. The panel you have should keep the battery charged with lights, water pump, radio, & furnace going if you aren't running the heat a lot. Remember you should also be able to charge your batteries with your tow vehicle. I can tell you that 2 deep cycle 6 volt batteries in series will last far longer than 2 deep cycle 12 volt batteries in parallel. With my wife & i we can live about a week on 7 gals of propane. We live year around full-time in a TT and have for 10 years. We have an 05 Tahoe 32' with a 12 ft slide-out.
Old Feb 21, 2008 | 07:35 PM
roostercrows's Avatar
roostercrows
when we go camping the battery lasts easily the full 7 days, the fridge, stove, furnace and hot water heater are all propane, so really all I'm running is lights and an exhaust fan
Old Feb 21, 2008 | 08:41 PM
alberta46's Avatar
alberta46
I understand that everything works on propane but what about the fan for the furnace I would think that would use a lot of power. I just wondered if I should get a bigger solar panel. I think I am going to look into the golf cart batteries for sure.
Old Feb 24, 2008 | 11:30 PM
fasthauler's Avatar
fasthauler
The amount of current the furnace draws depends on the type and size of the furnace. They can draw as low as 3.5 amps to a high of 9.5 amps. The average furnace draws about 6.5 amps. I use a 75 watt solar panel on my 5th wheel along with two 6 volt golf cart batteries. We run lights, furnace and TV on ours and the batteries will usually last 5 to 7 days depending on sun exposure and night time temperatures.
mmmPowerStroke
Jun 27, 2022 09:40 PM
annaleigh
13
Mar 30, 2017 10:35 PM
Raven17
All Things Towing
Jan 22, 2017 09:42 AM
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
Nov 8, 2016 02:33 PM
Torklift Sheryl
Jun 29, 2015 10:28 AM
