Why change exhaust?
Old Feb 20, 2008 | 09:11 PM
julieannsky's Avatar
julieannsky
Why change exhaust?
Hello all! Newbie here. stock 1997 7.3L PSD w/249,000, just purchased. I have disconnected the EBPV, thanks to the help of these forums, and am doing a DIY intake next, then a chip. But I won't be pulling more than 12K 15 times or so a year. What would I, if anything, do to the exhaust? I've been told the DP should be changed, but (keeping in mind, I'm new here,) will it shorten the life of the turbo(already Old)?
Thanks in advance for help!
Old Feb 20, 2008 | 09:13 PM
2 stroke man's Avatar
2 stroke man
no, it will LENGTHEN life of turbo, and engine due to low emissions. and, it will help fuel economy
Old Feb 20, 2008 | 09:14 PM
superduty4x4's Avatar
superduty4x4
Open exhaust = more power (and more turbo whistle ) The stock DP is pretty restrictive and somewhat of a pain to change but worth it from what I've read. DP is pretty affordable to do, under $300, then do a cat delete and you'll have a sweet setup. Also look into the 6637 air cleaner mod, really opens up the fresh air side.
Old Feb 20, 2008 | 09:16 PM
helifixer's Avatar
helifixer
it's like a new truck for a few hundred dollars. It should be mandatory.
2 stroke man
$300!!!!!?????? i got mine for $150! and it had the place in it to put my pyro, drilled, threded, and a bolt to plug it up.
Old Feb 20, 2008 | 09:21 PM
julieannsky
Bear with me, I knew nothing about diesels accept that they sounded cool, until a month ago. How would a bigger DP help the turbo? Are you saying, less restriction less load or pressure ( I don't know the right word) on the turbo, so happy turbo?
Old Feb 20, 2008 | 09:24 PM
julieannsky
Where did you get your's?
Old Feb 20, 2008 | 09:54 PM
2 stroke man
local performance shop. they are always cheap. price match if possible if you find something cheaper. pm me if u need contact info. but yes, the less restriction the better. and it sounds wayyyy better. also, remove the catalatic convertor (or have it done.)
Old Feb 20, 2008 | 10:07 PM
superduty4x4
I said under $300! I thought the Tymar was about $240 which seems to be one of the better ones out there. If I'm wrong, then that means it will be easier for me to "accidentally" acquire one for my future PSD!
Old Feb 20, 2008 | 10:19 PM
Todd525's Avatar
Todd525
I had tuffy bend one after looking at my buddies TYMAR. Cost me 80 bucks.
Old Feb 20, 2008 | 10:25 PM
2 stroke man
u suck lol
Old Feb 21, 2008 | 12:21 AM
powerstrokeddiesel's Avatar
powerstrokeddiesel
2 stroke... can you hook me up with a new dp???
Old Feb 21, 2008 | 12:39 AM
kawa's Avatar
kawa
Think of the down pipe as a funnel. Everthing is trying to go through the bottom of that restricted funnel and everything is getting backed up. You open up the bottom of the fonnel, say 4-6 times greater and the back up decreases and everything starts flowing and the turbo is so happy you can now hear the fat lady sing.
Oh, welcome to FTE
Rog
Old Feb 21, 2008 | 06:29 AM
2 stroke man
shoot yeah. 606-875-2421. u know where columbia is? he's 50 minutes from somerset heading west
Old Feb 21, 2008 | 10:26 PM
powerstrokeddiesel
2 stroke is that your number or his??? but no i do not know where columbia is... is that closer to me of farther away from me then you are???
