Sagging on one side. Will airshocks help ?
Old Feb 20, 2008 | 08:19 PM
FitchBanjos's Avatar
FitchBanjos
My pickup is sagging on the right rear corner about 1", probably due to fatiqued leaf springs. Will adding air shocks on the rear level it out? Thanks.
Old Feb 20, 2008 | 08:38 PM
Bill W's Avatar
Bill W
Well, If you ask me..... I would say you might be better off pulling the leafs out and take them to a shop that can rearch them. If you can handle the Remove and Replace part I bet the cost would be close to what Air shocks cost. Would be a good time to do the Bushings at each end also, and that is Cheap to do. IMO. Hey, Welcome to FTE!
Old Feb 20, 2008 | 08:40 PM
FitchBanjos
I agree but, I dont have access to a lift and dont feel comfortable removing them in my driveway. I was looking for an easier cure for the sagging.
Old Feb 20, 2008 | 08:56 PM
paul 64's Avatar
paul 64
installing air shocks might make it look level but may create a body roll problem when going around conners there is a place in dallas that will remove them rearch them witch would be best tommorow i can email you the name & number paul
Old Feb 20, 2008 | 09:04 PM
FitchBanjos
Sounds good PauL. Thanks. She rolls so bad now around corners that sometimes I think she is going to roll over. Really spongy. i thought the air shocks might stiffen it up a bit.
96f150
1997 - 2003 F150
13
Dec 23, 2016 04:25 PM
96f150
1997 - 2003 F150
Oct 28, 2015 09:45 PM
annaleigh
Jul 26, 2015 08:04 PM
Boss94
Mar 7, 2011 08:24 PM
jeff8362000
Nov 19, 2009 12:44 AM
