question
Old Feb 20, 2008 | 03:19 PM
Dan Taylor's Avatar
Dan Taylor
question
is there anyway to bypass the plastic cylinder thing with springs in it that connects around the pushrod of the master clyinder? truck wont start and its deff. an electrical problem. all other electrical things in the truck do work
Old Feb 20, 2008 | 06:31 PM
jr32560's Avatar
jr32560
is this thing your refering to on the brake or clutch???
Old Feb 20, 2008 | 07:03 PM
ford_boy_1996's Avatar
ford_boy_1996
If its the on the clutch just cut the two wires and put them together and then black tape them.
Old Feb 20, 2008 | 07:19 PM
Dan Taylor's Avatar
Dan Taylor
it is on the clutch but the cable that connects to the piece has like 6 cables.
Old Feb 20, 2008 | 08:06 PM
jr32560's Avatar
jr32560
clutch switch-well don't cut it just use jumper wires -on the wires till she starts-got a volt tester???use that and figure out which ones need to be connected-escorts are two wires-pull the plug-small jumper wire and she started-without pushing in the clutch
