Fuel Gel Question
Old Feb 19, 2008 | 09:59 PM
PAVEMENTMAN's Avatar
PAVEMENTMAN
Fuel Gel Question
Just Wondering If The Fuel Gels Up Will It Thaw Out When The Temp Rises And If So Will The Fuel Still Be Good. ????????
Old Feb 19, 2008 | 10:27 PM
maverick1701's Avatar
maverick1701
I threw in some Sta-bil when mine turned to gel and it seemed to work fine (after it turned back to normal)
Old Feb 19, 2008 | 10:34 PM
bkcowboss's Avatar
bkcowboss
When I lived in idaho, occasionally we would take the tractor out of the shop in 28 below weather, if you ran the rpms to high the wind from the fan would jell the fuel in the lines. Let it sit for 2 minutes or so and the heat from the block would warm it up enough to get it going again, the only reason that would work is the fuel in the tank was warm from being inside. It doesn't get that cold any more there.
Old Feb 20, 2008 | 06:23 AM
PAVEMENTMAN
Will The Fuel In The Tank Return To Normal.
Old Feb 20, 2008 | 07:45 AM
RealTruckMan's Avatar
RealTruckMan
FTE Sponsor
From what I was once told from a friend of mine who works at a bulk fill terminal, the oil in the fuel seperates from the water. This is what I was told.
Old Feb 20, 2008 | 09:29 AM
884x4broncoII's Avatar
884x4broncoII
its fine to run the fuel after its been gelled/thawed, iv done it before without any problems
Old Feb 20, 2008 | 09:36 AM
Todd525's Avatar
Todd525
I just did it a week or so ago. Everything is fine.
