Popping Noise
Old Feb 19, 2008 | 08:41 PM
Tigerball's Avatar
Tigerball
Popping Noise
Question to the masses. What causes a popping noise when I decelerate at low rpm? Only seems to happen when its cold. I have a 2005 F350 Powerstroke.
Old Feb 19, 2008 | 08:54 PM
drakul20us's Avatar
drakul20us
If it pops right after you let go off the throttle, it's normal, called a turbo fart.
Old Feb 19, 2008 | 09:16 PM
Tigerball's Avatar
Tigerball
Thanks for the quick reply. My first turbo and have only had it a week, so everything is new. I plan on using it to pull a 4-horse trailer and get a little nervous when I read some of the other comments. The dealer told me that the problem is related to the air filter. The mfg filter does not have this problem, only after market filters. Have you heard this before?
Old Feb 19, 2008 | 09:18 PM
Tigerball's Avatar
Tigerball
Is it common for "turbo farts" to not be consistent? Like I said before, only seems to happen at start-up?
Old Feb 19, 2008 | 09:22 PM
rollerstud98's Avatar
rollerstud98
Turbo fart is consistent, its true that you can hear it more with an aftemarket intake but it is still happening with the factory air box and filter. It usually occurs when you are getting into the throttle then quickly let off, all that air needs to go somewhere and it comes back out the air intake
Old Feb 19, 2008 | 09:24 PM
rollerstud98
I only have it happen to me when I'm warm since thats the only time I'm giving it some throttle
Old Feb 20, 2008 | 04:48 PM
Tigerball's Avatar
Tigerball
Thanks for the information
Blackbetty06
Sep 13, 2015 02:34 PM
creedua
Feb 19, 2015 09:49 AM
b4hntn
1978 - 1996 Big Bronco
Dec 14, 2013 10:24 AM
RobbyMartin
1997 - 2003 F150
Dec 25, 2009 10:15 AM
rts9364
2004 - 2008 F150
18
Oct 6, 2008 11:06 PM
