can i do this?
Old Feb 19, 2008 | 04:09 PM
messeswithtrux's Avatar
messeswithtrux
can i do this?
ok, been taking the kids snowboarding alot lately, and the trouble is, they are always cold and want hot chocolate, or they get hungry every 2 hours. so i was thinking of hitting up walmart and getting a power inverter and a cheap microwave and run it off my truck (at idle of course). can i do this or will i mess something up? does my truck have the power to run a micro? kids have been spending over 100 bucks a day at the hill, with a micro, i could cut it down to 15 or so. thanx.
Old Feb 19, 2008 | 04:15 PM
randomhero1172's Avatar
randomhero1172
You will need a heavy duty inverter! Im not very good with electrical but these are some of the inverters offered
http://www.northerntool.com/webapp/w...atchallpartial
Old Feb 19, 2008 | 04:25 PM
bdrummonds's Avatar
bdrummonds
Yes, you can, but you will need to figure out how many watts the MW pulls and then over compensate with the inverter. it will not be a cig lighter plug in model, but rather a model with aligator clips to go directly to the battery. IIRC a MW pulls a pretty large load on start up. also if you can afford it get a good inverter rather than a cheapy.
Old Feb 19, 2008 | 04:27 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
I can answer part of your question. Make sure the DC to AC converter has the Power Out (Watts) that the Microwave needs. Appliance specs vary from brand to brand. Check labeling before getting converter.
My guess is you will need a 1000 Watt Converter that Power's up to 8.4 amps. Sam's Club has some nice ones by *Power On Board* for low prices. "I think" Walmart only sells the 500 Watt by *Power On Board.*
Good Luck.
Old Feb 19, 2008 | 04:35 PM
Whitey Ford
They also have DC powered Microwave's. No need for converter. Here is one on eBay. Check around.
http://cgi.ebay.com/Samsung-Roadmate...QQcmdZViewItem
Good Luck.....
Old Feb 19, 2008 | 04:53 PM
F250_'s Avatar
F250_
Brandon, you're completely correct about the startup load. We have a large 1400 or 1600 watt MW at the house, and they say to not plug it into anything less than a 20-amp circuit, and they are correct. When I plug it into a 15-amp circuit, even with no other load, it will trip the breaker within 10 seconds every time. I had to run a dedicated 20-amp circuit just so we can use the thing.
Old Feb 19, 2008 | 05:01 PM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
I have a 3000 watt inverter in my motor home. It will run just about anything I can throw at it. In my truck I have a 450 watt and it has its' hands full just running my laptop and cell charger. It may do more for me if I were to hard wire it, but it just goes to the power plug on the dash. I would get at least a 1000 watt for your needs and forget alligator clips. Wire it right, with at least 8 guage cable.
Old Feb 19, 2008 | 05:24 PM
KelVarnson's Avatar
KelVarnson
I think you have to take a really good look at the numbers. A 1000 watt inverter, even if it were 100 percent efficient (it won't be), would pull 72.5 amps at 13.8 volts (motor running). You would definitely want to hard-wire this.
So figure the wattage actually drawn by the microwave, multiply it by about 1.25, and then divide that number by 12 volts, and that is how much current you'd draw out of the batteries. A LOT, in other words.
I think a Coleman gas stove on the tailgate would be a better solution.
Old Feb 19, 2008 | 05:29 PM
Markadeck's Avatar
Markadeck
I'd like to hard wire mine but do not want to drill any holes in my firewall. So seeing how as someone else has brought up the subject do any of you know of a good way to snake 8 to 10 gauge wire up to one of the batteries and not look like it was done at Disneyland?
Old Feb 19, 2008 | 05:31 PM
sflem849's Avatar
sflem849
That DC MW on eBay seems like the way to go IMO.
ORRRRR
This would be a great time to justify that Honda generator!!!
Old Feb 19, 2008 | 05:39 PM
guitarpicr's Avatar
guitarpicr
Coleman single burner propane -LOL- Much cheaper
Old Feb 19, 2008 | 05:42 PM
Markadeck's Avatar
Markadeck
Now you've managed to get me giggling. How about a campfire and we can put marshmellows in the hot chocolate, maybe a smore or two.
Old Feb 19, 2008 | 06:40 PM
jwhitetail's Avatar
jwhitetail
How about two big stanley thermos full of hot choc. and make them some sandwiches till you get home!!
Old Feb 19, 2008 | 06:46 PM
gunnertom's Avatar
gunnertom
Pilot truck stops offer a combo deal ,mw and inverter read to go .sorry I don't remember the price.
