dave4321
Old Feb 19, 2008 | 03:17 PM
dave4321's Avatar
dave4321
dave4321
Hi. I have an 89 F150 with an older 302 (points & coil) I'm guessing around 1970's
Old Feb 19, 2008 | 05:59 PM
Fomoko1's Avatar
Fomoko1
Welcome Dave, great to have you on board.
Lots of great info on your 89 F150 and the older 302 in these 1987 - 1996 F150 And Larger F-Series Trucks forums: https://www.ford-trucks.com/forums/forum28/ & Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W): https://www.ford-trucks.com/forums/forum55/
Visit and post your intro in the local WA chapter: https://www.ford-trucks.com/forums/forum188/
Old Feb 19, 2008 | 07:45 PM
dave4321's Avatar
dave4321
Of course I joined the forum because I have a problem...I was going to adjust the timming and loosened the locking bolt on the dist. So it still wouldnt turn. I thought I'll just tap it with a hammer. Wouldn't move, so I got a bigger tool. still wouldn't turn. I decided I would pull the dist. Nope not today. so I got a Bigger tool (crow bar) Well, it moved unfortunately it was just the housing. So now I have a shaft sticking out of the engine and I STILL can't pull it. Did I mention this was an after market dist. I can see the camshaft gear and the dist. gear and both turn when I turn th eengine by hand. HELP any body???
Old Feb 19, 2008 | 07:58 PM
Fomoko1's Avatar
Fomoko1
Hi again Dave, this forum isn`t moderated for tech replies so go into the two forums I`ve supplied links for. Just click on one of the links and in the upper left corner you`ll see the ''new topic'' button to click and then post away.
Fmontec150
New Member Introductions
Feb 19, 2008 05:54 PM
mike_rockwell
Nov 26, 2007 02:31 AM
38mainst
May 13, 2007 12:03 PM
rzuehlke
Mar 26, 2007 12:22 PM
hdchoppers
Jan 3, 2007 01:22 AM
