Modular V10 (6.8l)
cold start engine knock
Old Feb 19, 2008 | 10:39 AM
geraldo14's Avatar
geraldo14
Hey guys,
I have an 02 F250 SD 4X4 V10 with only 40K miles on it. Lately when I cold start the engine, it sounds like the bottom end is knocking until the correct oil pressure is reached along with total lubrication. If I turn the engine over just a few cranks without actually starting the engine first, it doesn't happen. Any ideas? I do have an extended warranty, 7 years or 100K miles.
Thanks....
Old Feb 19, 2008 | 10:55 AM
specializedcc's Avatar
specializedcc
Are you using 5w30 or 5w20? If not give that a try
Old Feb 19, 2008 | 11:13 AM
Big Orn's Avatar
Big Orn
Make sure it's actually a knock instead of a "slap". The "slap" is just the nature of the beast on these modular engines.
Old Feb 19, 2008 | 12:16 PM
teamgsxr's Avatar
teamgsxr
Are you using an aftermarket oil filter w/out the drain back valve ? My '99 did the same thing until I went back to using the Ford FL820 oil filter and it quit.
Old Feb 19, 2008 | 04:04 PM
geraldo14's Avatar
geraldo14
thanks for responding you guys. The last oil change I did, I used 5W-20W oil with a Fram oil filter. I didn't know about the drain back valve, is that inside the Ford oil filter?
Old Feb 19, 2008 | 04:36 PM
Big Orn's Avatar
Big Orn
What does an anti-drainback valve do for a vertically installed oil filter?
krewat's gonna kill me for asking that, I know.....
Old Feb 19, 2008 | 05:13 PM
msbweiland's Avatar
msbweiland
Fram=suck, and added engine wear.
Old Feb 20, 2008 | 02:44 AM
skipperw's Avatar
skipperw
Mobil 1 5-30 with Mobil 1 Filter will eliminate all noises.
Old Feb 20, 2008 | 09:26 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Any filter that says it replaces an FL-820S has an anti-drainback valve.
The one thing I noticed when I first changed the oil on my '01 was that the owner's manual calls for an FL-820S - not a plain regular FL-820
The "S" is for silicone anti-drainback valve. The Fram XG and TG series have them, the regular PH doesn't.
I've been using Fram for going on 25 years now - never an issue. My brother-in-law sells them wholesale to boat mechanics in the tri-state area, and never had a warranty claim. The rest of the filters he sells, he has. Go figure.
Anyway...
Ron, if you pump water up a hill, and turn the pump off and leave the valves open, does the water flow back downhill?
Old Feb 20, 2008 | 01:51 PM
Big Orn's Avatar
Big Orn
I knew better....
It never runs uphill...
Old Feb 20, 2008 | 07:55 PM
msbweiland's Avatar
msbweiland
Cut a Fram apart and compare it to a Wix or fleetguard. That'll tell the tale.
Old Feb 22, 2008 | 03:36 AM
skipperw's Avatar
skipperw
Go here if you have any questions about Oil or Filters.
http://www.bobistheoilguy.com/
