rough runnings
Old Feb 18, 2008 | 07:31 PM
4x4 dave's Avatar
4x4 dave
rough runnings
I have been having a problem with the truck seems like its running really rich changed all the normal stuff plugs cap rotor someone said the problem might be w/ the map sensor or the o2 sensor where are these located? thanks, dave
Old Feb 18, 2008 | 07:48 PM
rikard's Avatar
rikard
Check to see if the FPR (Fuel Pressure Regulator) diaphragm has failed. Pull off the vacuum hose attached. If fuel or fuel smell is present its probably leaking drawing fuel into the intake manifold
good luck
rikard
