help.....
Old Feb 18, 2008 | 02:56 PM
muddingmcdude's Avatar
muddingmcdude
help.....
soo my old 94 turbo diesel 4x4 its doing wierd things like we willl loose all volts and then it wont shut off by the key and the od light keeps blinkin and doenst go in to over drive but when the od light isnt on the tranny shifts fine i checked the tps i readjusted it soo and but the od light still blinks wont go into overdrive and it stilll looses allvolts and then it wont shut off?? me and my buddie are lost here i have a feelin once we fix why it doesnt shut off somtimes we'll fix the tranny too
Old Feb 18, 2008 | 08:18 PM
muddingmcdude
cman guys one of you had to shut your key off once and everything in the truck shuts off but the motor doenst problem or the tranny od light blinking ???
Old Feb 18, 2008 | 08:33 PM
George D.'s Avatar
George D.
The od light blinking means you're trans is in limp mode only second third and revers I think. and realy hard shifts don't drive very far in limp mode it will destroy your trans and they aren't cheap. mine went into limp mode this morning pulled over cycled the key and it was fine. if your FLPS, "TPS", is adjusted properly then you are either loosing tach or vss signal to the trans or it is registering a slip.
Is your speedo calibrated corectly? are the speedo and tach reading correctly when it gose into limp mode? What does you're trans fluid look like? Do your two problems always hapen at the same time or are they seperate problems?
for the not shuting off am I understanding correctly that you turn the key off and it keeps running but the volt gauge drops off? it could be the ignition switch or the fule shut off solinoid. How do you get it to shut off? If it shuts off when you un plug the fule solinoid then the solinoid is workig properly.
Old Feb 18, 2008 | 08:40 PM
George D.'s Avatar
George D.
oh and if its not the fule solinoid that doesn't necesarrally mean its the ignition switch.
Old Feb 18, 2008 | 08:44 PM
George D.'s Avatar
George D.
Heres a pick of the fule shut off solinoid in case you don't know where it is.
Old Feb 18, 2008 | 09:55 PM
muddingmcdude
yeah you have to pull the shut off sylnoid but it seems like the only time it donsnt shut off is when we loose all volts if you let it sit for a day it works fine.... shuts off fine and everything the od light i dont know it will flash even when you restart the truck my budie replaced the nuetral saftey and a synoid in the tranny the flpl was replacced bout 1 year ago it shifts really soft like i said tho i guess he was driving it in the morning today and everything was fine then he starteeed it again and it was on and off and wouldnt go into overdrive?? i think its time fora mechinic
Old Feb 18, 2008 | 09:59 PM
muddingmcdude
oh im sry no it wont shut off like you will be driving down the road you watch the volt gauge drop and if you try to shut off the truck it wont but everything in side the truck will shut off liek radio blower windshield wipers but the truckk still runnin soo there must be a wire that is shorts constant power to the injection pump??
Old Feb 18, 2008 | 10:36 PM
George D.'s Avatar
George D.
Maybe or there could be something wrong with the switch you might want to search the forum for the not shuting off thing I think there was a post on here some where just this week end and they were saying something about some lever in the steering colum. not too familliar with the ignitons on thees though.
see if your local parts store can pull trans codes for you might give you an idea why its acting up.
mine gose off with cycling the key cuz its registering a momentary slip that I think is caused by my FLPS being out of adjustmen and causing line presure to be off under the right circumstances I need to adjust that soon.
