Do it yourself door panels
Old Feb 18, 2008 | 12:32 PM
thunderbirdreg's Avatar
thunderbirdreg
Thought you guys might be interested,I did not like the aftermarket panels available,and the $100.00 dollar price tag!So I made some templates out of bristol board,copied them on thin sheetmetal.Made up the design and using 1/4 inch high density foam glued the pieces on the metal with contact adhesive. I then took some white vinyl and glued it on. I am happy with the results and it costed me $11.00 dollars including the glue.
Thought you guys might be interested,I did not like the aftermarket panels available,and the $100.00 dollar pricetag!So I made some templates out of bristol board,copied them on thin sheetmetal.Made up the design and using 1/4 inch high density foam glued the pieces on the metal with contact adhesive. I then took some white vinyl and glued it on. I am happy with the results and it costed me $11.00 dollars including the glue.
Old Feb 18, 2008 | 06:03 PM
customcab66's Avatar
customcab66
I used the original panels and put material over them and only spent about $10 and about an hour of my time.
Old Feb 18, 2008 | 07:49 PM
henry.509's Avatar
henry.509
Door panels look nice. Did you use the spray on contact cement? I want to do mine with a dimond patern but can't find any spray on contact cement.
Old Feb 18, 2008 | 08:09 PM
Customcab's Avatar
Customcab
Nice work; like the panels; Also weclome to FTE. Keep up the good work. I'm with ya on cost; also the new panels are made very cheaply; but I have to omit I purchase some for my 65. I was to lazy / lacking the brains to fab mine. I did partially decide on black due to the cost of $50 difference between the three avaiable colors at the time.
Nice work..
Mitch
Old Feb 18, 2008 | 08:14 PM
julie 54's Avatar
julie 54
Henry 509 hpw bout 3m super trim adhesive its in spray form and strong enuff for headliners? part # 08090 Julie
Old Feb 18, 2008 | 08:18 PM
henry.509's Avatar
henry.509
Great 3m super trim adhesive . Need to know where to look . auto paint supply ?
Old Feb 18, 2008 | 08:31 PM
julie 54's Avatar
julie 54
any NAPA or auto parts store should have it Julie
Old Feb 19, 2008 | 01:49 AM
customcab66
I did not use glue just used the trim to hold the material in place.
Old Feb 19, 2008 | 03:29 AM
thunderbirdreg
Hi I just used brushable type contact, I did not have any remnants of the old panels to use as a template,so it made it a little harder making the patern,but was worth it. I will post some better pictures tomorrow.
Old Feb 19, 2008 | 02:31 PM
thunderbirdreg
Pictures are in my gallery
Old Feb 19, 2008 | 04:20 PM
camperspecial65's Avatar
camperspecial65
Thunderbird...how long ago did you do them ...they look great!!!
- cs65
Old Feb 19, 2008 | 05:17 PM
thunderbirdreg
I just did them last week ,I have only installed the driver side ,I will install the passenger side this weekend.
Old Feb 19, 2008 | 06:11 PM
cathoderay's Avatar
cathoderay
nice panels i was wondering were you got the clips to hold the molding on mine all broke when removing the old panels i have some new panels that are hand tooled leather withthe same pattern as my saddle and would like to put them in my 65' one ton that is use to pull my horse trailer yours look good thanks bob
Old Feb 19, 2008 | 06:27 PM
Payner44's Avatar
Payner44
thunderbirdreg, tried sending a PM but you don't accept them...
Old Feb 19, 2008 | 06:50 PM
thunderbirdreg
How do I accept pm"s do I have to apply something on the site? I got the clips from a scrapyard but it was all I could find
