Cracked manifolds...thinking about headers
Old Feb 18, 2008 | 11:11 AM
Itch71's Avatar
Itch71
Both my exhaust manifolds are cracked (which I understand to be a relatively common occurance) I'm not necessarily looking for increased power, I just want to fix it and not have the problem recur a couple of years down the road.
Question is, will shorty headers hold up better in the long run than stock replacement manifolds? I'm assuming the thicker the flange the better? And also what difference does the primary tube diameter (1 1/2" vs. 1 5/8") make?
Thanks
Itch
Old Feb 18, 2008 | 01:07 PM
dkf's Avatar
dkf
A set of shorty steel or stainless headers are not prone to crack like cast iron maifolds. Even if a header does crack or break it can easily be welded. Cast Iron can be a pain to weld and once welded are more prone to crack again.
You can get a set of shorty headers to bolt up in place of the stock manifolds with no modifications.
You should get slightly more low end torque with a smaller primary tube diameter. With a stock engine I see no need to go with the larger 1 5/8" dia. As far as flanges go thicker is better. A 3/8" thick flange is a good thickness.
I have a set of cheapy Dynomax headers on my 74' F-100 for 8 years now and they are still in good shape besides a little rust.
Old Feb 18, 2008 | 01:22 PM
Itch71's Avatar
Itch71
Thank you very much
Itch
