EBPS deletion
Old 02-17-2008, 07:19 PM
jason cavinee's Avatar
jason cavinee
jason cavinee is offline
EBPS deletion
if i get a pedistol with out the EBPS do i have to get a high floe turbo outlet? and is there any thing else i should know before i do the deletion?
Old 02-17-2008, 08:01 PM
ron's power stroke's Avatar
ron's power stroke
ron's power stroke is offline
yes you can but why??? the point of the non EBPV pedistal is to take the EBPV out..
Old 02-17-2008, 10:00 PM
jason cavinee
i guess i dint relize you could just take it out. sorry im not a genius when it come to things like this thats why im asking questions!
Old 02-17-2008, 10:02 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
PowerstrokeJunkie is offline
Don't get the valve confused with the sensor. The EBPS is not affiliated with the turbo pedestal or valve. What you are looking at removing is the Exhaust backpressure VALVE.
Old 02-18-2008, 03:41 AM
ron's power stroke
what are you trying to do by going to a non ebpv pedestal ???maybe we can help in a nother way..
Old 02-18-2008, 06:36 AM
Izzy351's Avatar
Izzy351
Izzy351 is offline
I'll dip my toe in this one... My answer to the OP would be why would *NOT* get the high-flow outlet after doing all that work of pulling the turbo and replacing the pedestal? The benefit of the EBPV delete pedestal is removing a source of oil leaks. The benefit of the opened up outlet is better flow which should mean lower EGTs.
I'd even add that since you're yanking the turbo to do all that, invest in a set of bellowed up-pipes so you don't have to worry about them leaking in the not-so-distant future.
