Timing gears
Old Feb 17, 2008 | 02:51 PM
harrisford's Avatar
harrisford
Timing gears
I've got a '92 460 and it has the occasional backfire. what is this caused by? i was also talking to my shop mechanic and he said i have plastic timing gears. do they wear badly? and if so can i get a kit to change them?
Old Feb 17, 2008 | 02:56 PM
monsterbaby's Avatar
monsterbaby
replace the timing chain set with an aftermarket one and it will do away with the factory "plastic" timing gears (actually made out of nylon but close enough)
Old Feb 19, 2008 | 11:47 AM
fasthauler's Avatar
fasthauler
I would use a good Doubler Roller set. The single chains are notorious for stretching. Also since this is an EFI engine set up the chain at the straight up (0) position. A lot of people get caught up in the earlier settings of advancing the cam, but this doesn't work well with the EFI engines. Also the backfiring is probably a different problem That chain would have to really stretch to cause backfiring. Usually a vacuum leak, a lean condition or distributor problems cause backfires.
Old Feb 19, 2008 | 03:20 PM
hotrodmerc's Avatar
hotrodmerc
My 88 FI 460 had the chain in straight up and it was a factory double roller.
Old Feb 20, 2008 | 01:32 AM
fasthauler's Avatar
fasthauler
Thats a new one on me.
Old Feb 20, 2008 | 04:01 PM
leadmic's Avatar
leadmic
All EFI motor use dubble roller chains stright up.
Leadmic
