Wiring Linear actuator
Old Feb 17, 2008 | 02:49 PM
mt54's Avatar
mt54
Need a little help !
I have a linear actuator with no directions. The motor is labled 12v also says Blue & Geen wires to motor/ red,black,yellow are +5v ground sensors.
No other info avialible.
I have found that green pos./blue neg. = motor out
Blue pos. / green neg.= motor in
any help on how or what the groud sensors are for, or how to wire this thing up would be great.
Thanks
Old Feb 17, 2008 | 04:48 PM
sdetweil's Avatar
sdetweil
I assume that the red/black/yellow are the sensors for all the way out and all the way in. surprised they take +5.. I would have expected ground.
Sam
Old Feb 17, 2008 | 06:33 PM
mt54's Avatar
mt54
Thanks Sam,
after some research I've found that the three ground sensor are for a switch sytem if you want the actuator to stop in various differnt positions other than full open or full closed.
If I want only full open and full closed then I think I need to wire though two relays to reverse polarity of the green and blue. Does That sound right ?
Old Feb 17, 2008 | 07:29 PM
sdetweil's Avatar
sdetweil
sounds about right to me..
Sam
Old Feb 18, 2008 | 12:40 PM
mt54's Avatar
mt54
wired it all togather on the bench with two relays works great.
Thanks Sam for your input.
