bearing placement
Old Nov 24, 2002 | 05:03 PM
rustynuts's Avatar
rustynuts
bearing placement
i removed the main bearings and i want to know if the bearing with the groove should be on the block side or the cap side.
Old Nov 24, 2002 | 06:01 PM
TMI's Avatar
TMI
bearing placement
Grooved bearings go in the block. When you do it, it will make sense
because the groove will allow the oil to get to the crank, the other bearing will shut off the oil flow to the crank.
Tim
Old Nov 24, 2002 | 09:19 PM
Franklin2's Avatar
Franklin2
bearing placement
