Use a different IP and injectors on my 7.3
Do you have a factory turbo? if so I wouldn't recomend it. For the injectors look at the leter code its located on one of the flats of the hex on the injector. if you get injectors with that code you wont have any problems. they should be e codes if non tubo or g codes if it came from ford with the turbo.
It is NA (not a turbo) . The current injectors are code E to match the the model pump I have . I would switch to the older injector to match the older model pump . I just wondered if there could be any differences in 6.9 and eariler model Stanadyne DB2 Ford IDI injection pumps ( eg advance or fuel output) that would cause problems if used on the 1993-1994 7.3 . - Thanks
It appears that some of the earlier model IPs will fit ( linkage / AT stuff ) . However it is my ondersanding that the code E injections are mean to be compatible with the DB2-5028 or DB-5013 IPs ( have a slightly higher pop pressure . Does this matter in the real world ? Would I have to change the injectors to the early model codes to be compatible with the early model IPs ?
--Thanks
--Thanks
