block ID
Old Feb 16, 2008 | 08:04 PM
bigblueovalman's Avatar
bigblueovalman
block ID
Where is the block ID and year located on a 351 Windsor? Looked all over the block under the heads, behind the bellhousing to no avail. HELP!!
Old Feb 16, 2008 | 08:12 PM
dragogt's Avatar
dragogt
here this ought to help https://www.ford-trucks.com/forums/3...6-10-06-a.html
Old Feb 16, 2008 | 10:29 PM
bigblueovalman
re to block ID
Thanks for the info you sent, but I still need to know where the suffix is located on the BLOCK. I know it is a later block with the dished pistons in it (80,s) I don.t know what I,m buying unless I find the casting number somewhere on the block.
Old Feb 16, 2008 | 10:51 PM
dragogt's Avatar
dragogt
there cast into a flange on the left side of the block, right above where the starter bolts up. you may have to pick up the motor to read it.
Old Feb 17, 2008 | 01:45 AM
bigblueovalman
block ID
Thanks. I looked in all the other places that Ford blocks usually have their numbers. Have a GREAT day!
Old Feb 17, 2008 | 06:48 AM
dragogt's Avatar
dragogt
have fun and good luck.
