Headlight Removal
Old Feb 16, 2008 | 04:19 PM
Brutis's Avatar
Brutis
Headlight Removal
Hi all,
Does anyone know if there is a clip on the bottom corner of the headlight or does it just pop out. I have removed the two top clips and the manual says to remove the bottom clip but I don't see it. It looks like it just pops out but I don't want to force it?
This is on a 2000 superduty.
Thanks!
Jerry
Old Feb 16, 2008 | 05:11 PM
powerstroke1869's Avatar
powerstroke1869
no there isnt a clip on the bottom.. you have to pinch the sides on the bottom one and pull out.. i found it easier to remove the battery tray to access the bottom rod(or whatever its called). pull the top two rods out first and then once you pinch both sides on the bottom rod pull out.. takes a few tries
Old Feb 16, 2008 | 05:15 PM
Brutis's Avatar
Brutis
Bob,
Thanks! I will give that a try. Appreciate your help!
Jerry
