oil pressure quesstion
Old Dec 2, 2002 | 08:57 AM
dbarracuda's Avatar
dbarracuda
Hey guys.
Can anyone tell me where my oil pressure guage should me should be sitting at idle and when doing about 45 mph? I hav a 77 f150 w/400 c6.
thanks
David
Old Dec 2, 2002 | 10:12 AM
todd79_351's Avatar
todd79_351
my rebuilt 351M (hot) 800RPM in park 25-30 psi. In drive 20 psi. At 45 mph 60-65 psi.
Old Dec 2, 2002 | 09:46 PM
dbarracuda's Avatar
dbarracuda
todd 79
I dont have that kind of a oil pressure guage. All i have is the stock guage with the needle. Could you tell me about where the needle should be?
Thanks
David
Old Dec 2, 2002 | 11:28 PM
Sportcustom69's Avatar
Sportcustom69
Factory guages like you have are fine but if you really need to know what your pressures are and in turn need advice, you need to hook up a "wet" guage. Even just for awhile until you have an idea what what your true pressurs are. The factory guage is good to a point, but works off of electric resistance rather than true liquide pressure. They are cheap enough, easy to install, and if you have a decent parts guy, he will have a two way, mini manifold that will let you run a wet guage at the same time as you factory guage.
Old Dec 3, 2002 | 01:37 AM
Superdave's Avatar
Superdave
