Cat Delete
Old Feb 16, 2008 | 03:58 PM
Sabow's Avatar
Sabow
Cat Delete
I installed a 4" Cat Back MBRP and really like it. Would like a little more sound though. Thinking of deleting the cat and leaving the MBRP muff. What I do need is some advice and help.
(1) What are the chances I will get ticketed in Texas, I have never had an officer look under my truck - only been stopped a couple of times in the last 10 years.
(2) Do I need to put the CAT back on for inspection?
(3) Will it impact the turbo for better or worse? Back Pressure, longer life, lower egts?
(4) Where can I get a Cat delete/test pipe to fit the stock downpipe and attach to the 4" MBRP (which already attaches to the stock cat). I have looked but these are confusing to read about etc. Not sure how to get the right one.
thanks,
Sabow
Old Feb 16, 2008 | 04:20 PM
drakul20us's Avatar
drakul20us
1) the chances of you being ticketed are slim I'd guess, but you never know, depends on the cop
2)yes
3)faster spool up, lower egts
4)I got mine on ebay, I had the same setup, my cat-back attached to the cat, and now to the test pipe. you just gotta make sure that the pipe is 3.5"
Old Feb 16, 2008 | 06:06 PM
BobsF350's Avatar
BobsF350
where can i get a cat and muffler delete pies for stock exhaust system?
I find 4 inch stuff but no 3.5 stuff
Old Feb 16, 2008 | 06:11 PM
HeavyAssault's Avatar
HeavyAssault
A 3.5" MBRP downpipe and MBRP cat delete pipe will fit the OEM tubing. This will allow you to install the OEM cat if your state requires vehicle inspections.
Old Feb 18, 2008 | 08:16 PM
Green_Monster's Avatar
Green_Monster
hey guys I have a stock cat delete pipe that I will not be using, I am pretty sure I am going to leave my cat. If any one here is interested send me a pm. It is aluminized steel not stainless and is setup to go in place of the stock cat so 3.5" in and out.
Old Feb 19, 2008 | 11:02 AM
w_huisman's Avatar
w_huisman
GM: I'm interested, but can't PM or email you. Shoot me a line at w_huisman(at)yahoo(dot)com.
Old Feb 23, 2008 | 12:37 PM
Green_Monster
cat delete pipe in the classified section for sale
Old Feb 23, 2008 | 01:02 PM
hangon2me's Avatar
hangon2me
I have owned a Truck with out the Cat and one with. There is no difference in performance and EGT's. The MPG went down on the one with out the Cat. Unless you are going to go all out with a programmer, bigger Turbo and other Mod's, I would leave it on your truck.
Old Feb 23, 2008 | 01:50 PM
bruno6491's Avatar
bruno6491
HUH?? I saw an increase with power as well as a lower spool up time for the turbo
The EGT's went down about 100 degress and i gained about a MPG or so, any i only had 14000 miles on the truck when i removed it
Bruno
Old Feb 23, 2008 | 07:40 PM
Z-MAN's Avatar
Z-MAN
Any Suggestions For Cat Delete Pipe For A 4" Turbo-back Banks Exhaust Or Should I Just Get A Piece Of 4" Stainless And Mod To Fit?
Old Feb 24, 2008 | 01:30 AM
mnmwhit's Avatar
mnmwhit
I just put the MBRP cool duels on my truck, turbo back with a cat delete. The sound is great when you get on the throttle hard. On cruise I cant tell a difference in the sound. The power is noticable.
Old Feb 24, 2008 | 06:46 AM
Green_Monster
ZMAN
Go to one of the site sponsors or ebay for that matter 4" stainless cat delete pipes are readily available. do a search and you will find choices.
