Stock Ignition Capabilities?
Old Dec 2, 2002 | 02:32 AM
Big Blue4x4's Avatar
Big Blue4x4
I think my stock ingnition and distributor are hindering my rpms. At about 4500rpm the engine cuts out. In first gear, not a big deal. In second, it will barely rev past 4500rpm. Is this ingnition related, or do I have another problem? I have a remanufactured distributor and the stock ignition. The coil is a Jeg's 45,000 volt. The cam range is 1200-5200rpm. Any advice will help. Thanks.
79 F150 4x4 410m Built Ford Tough!(9.1:1,KB pistons,custom Comp Cams X-Treme 210/218-.508/.524,roller rockers)/c6/3.5:1 gears,4.11:1 soon, Edelbrock 750, 285/75R16 BFG Mudders on alumn. mags with New Drk. Blue paint.
65 Ranchero 170-6, 3on the tree, solid mags, New Bright Yellow paint
Old Dec 2, 2002 | 10:31 AM
shazam's Avatar
shazam
Well I'd have to say I don't think it's the stock ingnition and distributor that's holding you back. I'd have to lean more towards the valve springs .
I currently use a remanufactured distributor and a MSD 6AL and a Blaster Coil on my set-up and I can spin it to 8200 RPM's anytime I want for as long as I want.
Old Dec 2, 2002 | 11:05 AM
beartracks's Avatar
beartracks
...How about your total iginition timing?
Old Dec 4, 2002 | 09:37 PM
Big Blue4x4
The valve springs are the ones recommended from comp cams to match the rpm range. They also have dampeners. I checked all of them before I installed them for open seat pressure and closed pressure. They all came within spec. The installed heights are correct also.
I had a good distributor in there before and didn't notice a problem. It was a Proform High Performance blueprinted distributor. Something broke inside of it and the top part of the shaft will turn while the gear is stationary.woops.
My initial timing is set at 8 while my total without vac advance is 24 and with vac advance is 38.
Any suggestions?
79 F150 4x4 410m Built Ford Tough!(9.1:1,KB pistons,custom Comp Cams X-Treme 210/218-.508/.524,roller rockers)/c6/3.5:1 gears,Edelbrock 750, 285/75R16 BFG Mudders on alumn. mags with New Drk. Blue paint.
Old Dec 5, 2002 | 01:50 AM
Bill_Beyer's Avatar
Bill_Beyer
