steering box going out???
I replaced the drag link a few days ago because it seemed a bit worn out on the joints.....when the drag link was disconnected fromt the pitman arm, I noticed when I grabbed the pitman arm and shook it around, that there was a bit of movement. I cant tell how much movement visually, I can only tell by sound...a slight clunking sound. The sound seemed to come more so from the steering shaft/column, than from the immediate pitman arm area...though slight movement was at the pitman area. Once the new drag link was bolted up in place, I tried moving the pitman arm, and it was solid...no movement or noise...Is this normal?? Am I heading for an even lighter wallet????
