400 built cam choice
Old Feb 15, 2008 | 07:24 PM
hollenjoe's Avatar
hollenjoe
Hi, I have a 73 tang mach 1, I had a 351m fitted with headers and stuff in it... I decided on rebuilding the 351m into a 408, so I bought tims 0 deck 9.5cr pistons 30 over, 400 crank, etc.... Besides this I have a single plane small port maniforld, edelbrock performer 750 manual choke carb (1407), stock heads a bit ported on the exhaust side and milled 0.020", one being a 75 with 74,6cc chambers and the other one a 73 with 75,6cc chambers (obviosly they have less cc due to milling). So meanwhile getting on some more money to get a new camshaft and top new parts like roller rockers and ****, i have 2 camshaft available for my build and i was wondering on which one is the best choice. This is my fun driver and will be used on the streets, there´s nosmog regulations around here and would love to drag joking around, so, theres the crane hmv -272 2a with 272int 284 ext and the h 282 2 with 282 int and 290 ext, both with a little more than .500 lift. I will run on 91 octane, so whats my best choice?? opinions??? thanx...
also I might add that the scr i calculated it at 10 to 1....
Old Feb 16, 2008 | 07:02 AM
trinogt's Avatar
trinogt
With those stock open chamber heads, I think you may have trouble running pump gas with a high CR like that...
Old Feb 16, 2008 | 11:23 AM
hollenjoe's Avatar
hollenjoe
even with the huge overlap that the 282 290 cam has? in the calculator the dcr goes to 7.5 to 1, aint that cool with 91 octane?
Old Feb 16, 2008 | 03:22 PM
trinogt's Avatar
trinogt
Well, I am not familiar with that cam, but if you calculated the dcr to something that low, then you should be able to try it and you will notice very soon how well it works. I would check with the 335 series forum on network 54. Chances are, someone has experience with that cam.
dimora
176
Apr 26, 2018 08:00 PM
fiftyfordfloored
15
Mar 23, 2015 08:43 AM
dylansf23
18
Apr 26, 2014 09:51 PM
Kionga
Jun 11, 2005 07:13 AM
minnesota4x4
Apr 6, 2003 10:27 AM
