Window moving very slow, need advice.
Old Feb 15, 2008 | 02:12 PM
larspetter123's Avatar
larspetter123
The window on the passenger side front door is moving very slow when going both up and down. It seems to me that it is binding somewhere, but I am not sure. I am afraid to even open it now, because I fear the window might not go up again, and I will be stuck with an open windw. This has been a problem for quite a while, and it is worse when it is cold. But I have just not found time to investigate. Now I belive I just have to have it fixed. I prefer to do it myself, if the fix easy enough.
Anyone experienced similar issues with their window(s)?
Appreciate all the help I can get.
Thanks.
Old Feb 15, 2008 | 07:36 PM
kidwagon's Avatar
kidwagon
I have the same problem with mine. You can always get it back up if you pull it up with one hand while you press the button, but it is a royal pain. The local shop has lubed it a bunch, but it only helps for a couple of weeks. I would love to know if it is an easy fix, or if it is more likely a motor.
Ryan
Old Feb 16, 2008 | 05:13 AM
Downriver Thunder's Avatar
Downriver Thunder
I would love to know a fix too.
