1406 on 351m broken stud
Old Dec 21, 2002 | 02:11 PM
beartracks's Avatar
beartracks
Old Dec 23, 2002 | 12:44 PM
killer4x4's Avatar
killer4x4
got a edelbrock 1406 with a broke off air cleaner stud, whats the easiest thing to do here ? drill it out? JB weld another stud in? and suggestions would be helpful. thnx
Old Dec 24, 2002 | 12:57 AM
grclark351's Avatar
grclark351
how far down is it? sometimes you can turn em out w/a sharp pick.i'm not familiar w/the carb,can better access be had by disassembly?
Old Dec 24, 2002 | 09:20 AM
chris eck's Avatar
chris eck
Usually the air cleaner studs arent in that tight.Drill it out down the center for the correct size easy out bit.Screw in the easy out until it bottoms then back it out and hopefully the broken stud will come out with it.Pack the inside of the carb good to prevent burs from the drill getting inside the carb if your doing this on the engine or not.If this doesnt work drill out the entire stud and retap the hole to the correct thread size again .Good luck.
