Valve noise
Old Feb 14, 2008 | 11:14 AM
S.A.FORD's Avatar
S.A.FORD
Angry Valve noise
First time user great site! Problem 77 ford with a 390 600 cfm carb. If I set the timing to factery the valves rattle BAD when you hit the gas or pull up a hill and it also starts had after it warms up. I know it sounds like its advanced to high that was my first guess. Mybe timing chain?
Old Feb 14, 2008 | 11:46 AM
RCrawler's Avatar
RCrawler
If it is doing it mainly under load, it could be detonation (pinging).
Jason
Old Feb 14, 2008 | 11:56 AM
S.A.FORD's Avatar
S.A.FORD
O its pinging allright so whats the fix? I might not mess with if i have to tear into it too deep, it im going to swap it out for a 300 when i get the rebuild finished. (month 3 on rebuild)
Old Feb 14, 2008 | 12:03 PM
masterbeavis's Avatar
masterbeavis
I agree with RCcrawler, I think its detonation. Back off your timing a few degrees, and run higher octane gas. The proper fix would be to get your distributor re-curved. There are seveal writeups on the internet on how to do it yourself. Do a search on google for duraspark distributor re curve.
Also you might be running a touch lean? I dunno. Try backing off your timing first, see what happens.
Old Feb 14, 2008 | 12:59 PM
S.A.FORD's Avatar
S.A.FORD
Thanks i will give it a try.
Old Feb 14, 2008 | 04:16 PM
rbaker6336's Avatar
rbaker6336
if the timing chain is worn it will ping when you try to bring ignition timimg back to specs
a carbon buildup will also cause it
Old Feb 14, 2008 | 04:19 PM
masterbeavis
So you are saying that as the chain stretches, the timing retards? I hadn't thought about the effects of a chain stretching, I would have thought that it would not give that much unless seriously worn.
Old Feb 14, 2008 | 04:26 PM
rbaker6336's Avatar
rbaker6336
the will streatch a good bit and still run and the more wear the more timing retards
pretty easy to check with timing light
Old Feb 14, 2008 | 04:30 PM
masterbeavis
I understand what you are saying, however my mind is not allowing me to fully grasp the subject.... Ok, you state the chain retards as it wears. Moving the timing back to where it should be on the mark will alter the timing significantly enough to cause detonation in some cases??? I am not trying to question the validity of what you are saying, I am just retarted at the moment, and can't understand.
Old Feb 14, 2008 | 04:38 PM
rbaker6336's Avatar
rbaker6336
basically the distributer has to be timed with the valves,when the chain wears and the mark is on the crankshaft you are no longer able to time with the valves
Old Feb 14, 2008 | 05:43 PM
pdqford's Avatar
pdqford
I think of a sloppy chain as alowing the cam/valves/distributor to lag behind where they should be. Or, to say it the other way around, the crank gets ahead of the distributor. When the distributor calls for spark at, what used to be 6* BTDC, the crank is already at ATDC, causing the spark to be retarded.
To verify chain slop, rotate the engine until the timing marks are roughly lined up. Pop the distributor cap and watch the rotor. Rotate the engine CCW until the rotor JUST starts to move. Note the timing marks. Then rotate the engine very slowly CW until the rotor JUST starts to move. Read the timing marks. If you can rotate the crank over 10 degrees without the rotor moving the timing chain and/or sprockets are pretty loose.
